djkav Hello, If I set up a winter schedule to set the battery to charge to 100%, between 0030-0530h. Will the GivEnergy Inverter default back to ECO mode? Or, do I have to enable a setting in WW?
johalareewi If you are charging, WW should leave the ECO setting alone. AFAIK WW only changes it for exporting.
