Just taking a look at the great new Agile integration and I have a couple of questions:
Q1. Does the setting below mean WW continually polls my batteries SoC and send the charge instruction as soon as it sees the battery SoC drop below the specificed value, or is it checked/sent only at a specific time of day?
"Only send the charge instruction to inverter if the battery charge is below this value."
Q2a. Is solar forecasting integrated into the Agile charge schedule i.e. if 15kWH of solar is expected tomorrow, will the max battery SoC during my charge window be reduced to utilise solar to charge the battery to 100%?
Q2b. If answer to Q2a is no, is there a way to manually set the maximum SoC desired for overnight (00:00-08:00) charging so I can factor in my own solar foreacast?
