Capt_Rich I'm currently charging my battery during one of the free octopus sessions. I noticed the battery was only charging at 2.4kw so I jumped into the logs and can see WW set it at that rate, despite my WW battery rate being set at 3.4kw in the advanced settings. (WW ID open-departure)
admin Capt_Rich This is simply because you had the adjust charge rate toggle turned on in your Free 3Hr Octopus custom schedule.
Capt_Rich Ah ok thanks, I'll go back and check that then thanks. Just to get my head around that, I always presumed that setting was to adjust charge rate to the rate in the WW advanced settings, but it means something else?
admin Capt_Rich It means it will dynamically adjust the charge rate to reach target SOC by end time of your charge schedule.
