I set up a forced discharge to export remaining battery charge before the cheap overnight slot. This did not run on the evening of the day I set it up. Not sure why.
Following day (today) I set up another test schedule for with the same parameters (if SOC>25%, export until SOC=15%), to force discharge/export for 15 minutes whilst I could monitor effects. The discharge/export started at the scheduled time but continued after the time slot expired. Discharge continued even when I used the WW Pause function to try to stop the export. I had to turn the inverter off then manually reset to stop battery drain. Does the minimum SOC setting overrule the time setting and disable WW Pause?
Looking at the inverter settings on the Solax app, it looks like WW had set the inverter in Manual/Forced Discharge mode and that did not reset automatically at the end of the time slot.
Am I doing something wrong?
