Daily electricity usage (minus off-peak EV charging)
Please provide your typical electricity usage each day in kWh below. This will be used for predictive charging. You may want to update this value during different times of the year.
Above entry is manually updated. But I'd forgotten yo do a winter update.
Suggestion
- Allow more than one value to be set. In my case I'd probably have a heating season setting of say 60kWHh say 1st Nov to 30th April and outside that 30kWh (i charge at night and force export)
- Some users might like up to 4 period settings in a year?
- And/or option for a reminder to update by email of push notification? Of course i could set a calendar myself but easier if within WonderWatt?
tepid-topic
I've noticed my Nov usage and IOG cost showed a small but significant increase. Usage increase was expected as heating season. But generally thought battery & WonderWatt were ensuring avoiding peak slots. Unsure if WonderWatt failed to correctly adapt for changing slots. Or if Daily Usage setting caused it. Or??!!
No need for huge investigation as I'll try go monitor more closely and update.
