PaulN Don't use custom charge schedules when on IOG. WW takes care of this, including the default 23:30-5:30 slot.
PaulN When a smart EV charging slot is created by octopus, does that mean all your imported electricity is at the smart charging rate during that period or just what is used to charge your EV?
All leccy will be charged at offpeak rate. Up to a max of 6 hours or so.
PaulN If my EV is plugged in and there is a smart charging slot while I am trying to export (between 16:00 and 19:00) what happens?
Basically, don't plug your EV in when you have an export schedule set up. Otherwise it would just go into your EV.
