What import tariff are you on?
The main difference between outgoing and agile export are the 30 minute rate changes vs same rate all day.
WW has a separate scheduler for Agile where you can select individual slots for export rather than use the normal scheduler. If you are on Agile Import, you will probably be using the Agile scheduler already.
