So abit of an odd one:
- I turned OIG & Agile schedules off yesterday afternoon.
- I enabled manual import/charge schedule for 03:30-05:30.
This morning I noticed it had fully charged the battery between 23:30 and 02:00!
It then also did the WW scheduled charge/import between 03:30-05:30.
I don't see any instruction in the WW log to do a charge from WW for 23:30-02:00, and checking the Growatt inverter settings there is no charging schedule set now. The Growatt inverter doesn't seem to have any log other than Fault log, so can't see from that when/where the import/charge instruction was sent.
Do you think there was some left over OIG setting in the battery that was programmed before I turned it off or something else?
