Stuart1 If your battery SoC is not accurate and drops quickly, rather than fairly proportionally, this can happen.
There is little we can do about, apart from suggest you to either calibrate the battery or alternatively simply adjust your cut off SoC stop to a higher value.
WW simply calculates a roughly proportional depletion of battery. If SoC readings are inaccurate, this can end up being off.
