When the 'Battery Reserve % Limit' is updated ready for a Scheduled Export, the original reserve % is not being restored back after the export has completed and is defaulting to 4% which is the cut-off percentage. The 'Battery Reserve % Limit' on the AIO is set to hold back a user defined percentage reserved for the EPS in the event of a power cut. Should it not restore the original value back rather than defaulting it back to 4% cut-off?
