Jeff admin it did work, the instruction came in just after the start so I missed it as I checked it a minute before, sorry!
palaceben Looks good - although I thought it hadn't as it sent a 13:30 charge instruction at 13:30:00 and then again 2 seconds later! All a bit "last second" but as long as it works 🙂
KristianS palaceben Mine was even 'later' than yours at 13:30:05 - but to be fair, even if we up to a minute afterwards - we are still in the slot we want
admin KristianS Yeah, as you can imagine, we can't possibly be accurate to the second, especially with many schedules and commands being executed around those times.
KristianS There are also things outside your control. Presumably, your commands are only as good as when the GivEnergy API processes them..... I think the comment above from @Jeff was it appeared to have not been set, when it had, just about over a minute later
ALLENPATTRICK My charging period from 0200 - 0500 did not run this morning and there was no entry in the activity log. I subsequently created 2 x tests. Around 0600 1 was for a short SMART charge and the other fixed. These also shared a similar fate with no notes in the log. My id is. ‘Imaginary-risk’. Am I doing something incorrectly? Allen
Albo ALLENPATTRICK exactly the same issue for me this morning. Nothing in the logs. ID complete-refrigerator. Givenergy system.
markcurbishley Same here, no charge overnight, tried creating test charge slots this morning via online dashboard- nothing. BUT - can force charge if set via shine app parallel-nobody
deepee Same for me, overnight smart charge didn't happen, nothing in the activity log. I'm on a Growatt inverter. acrobatic-she
MarkP Same for me, fine yesterday, but nothing overnight on either of my 2 systems. Looks like commands not sent. Both systems are GivEnergy. All worked again last night must have been a one off
