  • Charge instruction hold set (468W), - not working
Hi
Below are details on a slot instruction that appears to have not been sent to the inverter.
The schedule this morning included a charge in the 5:00-5:30 slot
This resulted in an action in the WW activity log of
2024-04-09 05:01:05 83 %
Charge instruction hold set (468W), starting 05:00 Agile Octopus
However, the GE log shows what looks a no charge was integrated:
2024-04-09 05:02:14 You AC Charge 1 End Time Written Successfully 05:00 00:00 00:00 API - Inverter Settings - Wonder Watt - s87PbleP
2024-04-09 05:02:13 You Battery Discharge Power Written Successfully 476 3600 3600 API - Inverter Settings - Wonder Watt - s87PbleP
2024-04-09 05:02:13 You AC Charge 1 Start Time Written Successfully 03:00 00:00 00:00 API - Inverter Settings - Wonder Watt - s87PbleP
2024-04-09 02:58:43 You AC Charge 1 End Time Written Successfully 05:30 05:00 05:00 API - Inverter Settings - Wonder Watt - h48m81yX
The activity Graph also shows charging stopped at 05:00
I think this has happened where a "Charge instruction hold set (???W)" instruction has been sent in the last few days but not looked back to double-check.
Let me know if you need nor info or if I have done something incorrectly.
PS This was a slot added - the core window ran to 5am and the 5-5:30 was invoked with a "Click on a slot to toggle the selection" as I recall. This may be irrelevant as I ma not sure if this was the case when experienced previously.
    4watts Looks like the hold charge should not have been set in that scenario.
    We'll put in a fix.
    Hi
    what sort of ETA do you have for this fix as I need to decide how /if to looks for work around
      Looks like I've had very similar issue - battery charged then held and discharged a couple of times overnight with attempts at recharge. Instruction was to keep on charge u till 11.30 as I was charging the EV.
      downright-dig
