I'm not seeing any instructions in the activity log that WW is sending to my inverter. Based on my settings it should have done so.
I've entered the settings in UK timezone, I'm starting to suspect that WW is interpreting my UK based timezone setting entries as entries in my very different timezone but I have no way of verifying this since nothing is happening.
Example : I want to start discharging battery at 17:00 UK time when battery is at least 95%. If however WW interprets this as being 8am, then the battery is empty and nothing would happen.
Strangely enough when I created the account, it registered the timezone as 9hrs behind GMT (which is probably taken from the Google Login associated home timezene (??)), since that's not where I was (GMT-6) at that time, , which tells me WW does not take the time from the a location setting associated to IP address ?
Whatever it is, I can't find out for sure and hope the developer can shed a light to this and allow me to hardcode the timezone when setting up the account.
