Yesterday I noticed, that even after an hour since prices came out, my portal had not pre selected any slots. I de-activated the window and then re-activated it and the slots populated
I thought it was just a glitch but today, 30 mins after tomorrows slots are showing it still has not populated any of them automatically
Pity , no auto selection , altho at least it does seem to be holding onto any manual selections ?
No auto selections for me as of 21:20 today - odd
    KristianS Yeah, depends on your active window cut-off and whether there are still slots selected in your current window.
    Two runs that will prepopulate any empty windows happen at 22:40 and 23:40.
      My active window is 00:00 - 16:00 and has been since week 2 of using WW.
      I threw the toggle to Deactivate and then set it to Active and the slots were populated as expected. I was most likely going to sleep before 22:40 / 23:40 so I thought that was the best method to make sure that the slots were locked in for last night.
      admin So I am now officially confused. Slots used to populate by about 16:30, What has changed? What window time should I have to make this happen?
      Unfortunately same for me today. 16:45 and nothing selected for tomorrow. Interestingly, the 22:30 I deselected yesterday, is now selected again and yes, I deselected it after my toggle off and on again
        I am not going to do that today as I have 90% SoC in the battery and just see what happens overnight
        Agreed - second day running that the post new Agile rates auto-populate has not populated tomorrow's slots (Watt-ID: private-selection)
        I'll leave it as is for no and see what happens later.
          I have just accepted that somethings awry and will eventually get sorted …. in meantime , what can we do other than select the attractive slots manually ? I appreciate that we are all contributing to this beta experiment …. but it can indeed be frustrating when we seem to get over one hump and in doing so , something else goes out of kilter . I suppose that overall , we are getting there !?
          There are two more Auto Populate runs at 22:40 and 23:40 from previous posts from Admin that I think will sort it. But hopefully I shall be asleep by then 😉
          Hi Admin, back to my question from earlier today please
          " So I am now officially confused. Slots used to populate by about 16:30, What has changed? What window time should I have to make this happen?"
            admin Correct. But that's to enable the Agile "price below" which is set to 0p to populate. I.e. I only want to auto-populate the slots priced below zero pence and nothing more.
            This was working last week.
              Shockwave What has changed is the changes for only populating below threshold prices on the first populate run after new tariffs have been published.
              That had a knock-on effect, which we're rectifying now. Deployment underway.
              Also - your 00:00 - 00:00 window is gonna throw up issues due to same start and end time - we should put a validation message in place for that.
              A window of say 23:00-22:00 might work better. Alternatively you could break you Agile charge windows up. Some use 00:00-08:00 and another 11:00-16:00 for instance.
                admin Thanks, I only changed the slot timing to see if that would fix the problem, it was previously set to 00:00 - 23:00
                The slots should be populated now. Deployed as part of Release 558.
