Sindidziwa Just had a new Growatt SPH 6000 inverter installed, which has been picked up in settings OK. The dashboard looks strange though as it isn’t showing SOC for the battery and also nothing for the current usage as well. Any ideas?
Sindidziwa It now seems to be showing the correct SOC%! Must have just been taking its time to find the data.
Sindidziwa Having the same problem in that the SOC is showing as 0% and the schedule set up to charge in the afternoon is failing (the night time one seems OK). Any ideas @admin ?
Sindidziwa Yes, the one I have linked here is connected to 13 kWh Growatt batteries, the other is not connected and basically feeds direct to the meter.
