Hello,
I am getting on very well with using Wonder Watt to control my Givenergy system. Thank-you for all your hard work.
However I have a small issue in the calculation for discharge time. I believe the end time is adjusted for just after 4% charge is expected? I am finding this isn't quite long enough as occasionally my inverter is backing off exporting as the Grid voltage goes above 256v for a few seconds (a problem of too many systems exporting at the same time and lifting the voltage above my nominal 250v). Which of the settings would extend the adjusted period? I tried the battery charge power but this affected what was written into the charge and discharge current registers giving me lower powers. I am now trying the battery capacity setting (adjusted to 110%). Is that going to work?
(A possible system enhancement could be to verify the charge has reached 4% at the end time and give it a boost discharge to the end of the selected export slot if not?)
Watt-ID: elaborate-routine
