admin Yes. Outgoing Agile is normally around 50% of the import rate so best times to export are 4pm to 7pm. At the moment I just mentally divide the import rate by 2 to get an estimate of the export rate.
I manually adjust the number of overnight slots so I don't end up with a full bettery when the sun comes up, aiming to get it to 100% in the afternoon. However, if the daytime export rates are higher than the overnight import rates, I can go for a full battery charge overnight.
Recently, Agile overnight rates have been higher than late morning / early afternoon rates and I am looking to minimise exporting the solar PV for less than i paid to charge up the battery overnioght.
I am pretty sure you have got a lot more usefull features to plumb in but if you were thinking of adding exprot rates, I would be interested.
