Thanks for your comments and suggestions.
1) GIV AIO charges and discharges @ 6kW. The actual capacity is around 14.5kWh (although rated at 13.5kWh) so, you are right, a full charge or discharge takes 5-6 half-hour slots.
2) We live in an old property with no mains gas and the size of our PV installation is limited by Listed Buildings consent. So our net electricity consumption is quite high, even in summer. The number of days per annum when our PV generation exceeds our consumption can be counted on the fingers of one hand.
3) My aim, and I imagine that of many/most other WW users, is, through time-shifting, to arbitrage (I’m an engineer not a banker!) the price differences between OCT Agile import and Fixed export to save myself a few bob and help flatten out the UK’s green energy demand.
4) So I need to store as much grid energy as possible priced below the current 15p export rate, for our own use or for re-export. Unless I’m overlooking something, this means having my AIO at or close to empty just as each of the two daily low price windows begins. At the moment, I do this manually. My WW Feature Request is, if possible, to automate this.
5) For OCT Flux, when export timing is critical, a different strategy would clearly be required.
