Again I may have missed this (did check the FAQ this time đź¤), but is there a way of setting separate charge discharge rates? At the moment, I have the settings for battery at 1.5 kW (9.5 kW GE battery) in the advanced-battery rate setting, and the inverter at 3 kW, as I took this to be the max rating of the inverter. With these, my system seems to charge at 1.52 kW, but discharge at 1.42 kW, (the sliders in the GE app are both at 1.52 kW) and I’d like to balance them out or sometimes charge faster than discharge or vice versa).
