jonnyjameswalker Hi there. I usually have agile charge window between 0000 - 0600 but also have the auto charge when price drops below 3p the same as my harvi. The price dropped below 3p between 0600-0700 this morning and the harvi drained my battery and did not charge from the grid like it was supposed to. How come this happened?
admin jonnyjameswalker Thanks - right, looks like an edge case because your end of your Agile charge window was effectively the start of the cheap slot which was outside. We'll get a fix out.
Surfcornwall My AIO has stopped charging via your APP for the last two days my user is wicked-water Error message: Error accessing data - check API key [********] Ive edited my API key Thank you in advance Kind regards Malcolm
admin Surfcornwall Update API key and make sure you don't forget to click the Save button at the bottom of the Settings page! :-)
