Over the last week, Wonder Watt has been working fantastic, doing everything right, importing from the grid between 2-5 in the morning and exporting between 16-19 in the evening. In between, it would prioritise battery use over grid import. However, with the latest 16-19 slot it not only did not export the battery at full power as instructed but also reset the system to take power from the grid, i.e. eco does not seem to have been reset. Before it would prioritize using battery power over the grid. The result is that I used up expensive electricity right during the slot when I aimed to export and am left with 100% batteries for the rest of the night using electricity import instead. May I assume it will reset to eco mode with the next 2 am slot? (I am hesitant to reboot the inverter as I am abroad for a period and it tends to lose its wireless connection straight after, requiring physical intervention by removing and reinserting the Wifi dongle). This is the only hiccup I have had so far in what is a fantastically simple to operate service you provide.
