Interesting case this one.
WW_id elaborate-routine
I have been using the smart charging for a few days and am very pleased with the way it works when the Agile prices are too high to be worth considering - well done.
However last nights schedule didn't stop charging at 5am with the battery stuck at 100% until I manually disabled the charging at 7am.
I had set up a smart charge schedule for 2am to 5am as usual. But the WW log showed a timeout error on setting this up. The GivEnergy log showed it had accepted the enable charging command and the set start time to 2am command but had timed out on the stop time command of 5am. Consequently the battery inverter was quite happy charging from 2am to 0am (its previous setting) hence was still charging at 7am. I presume that WW didn't attempt to reset the charge schedule at 5am (there is nothing in the GE log at that time) as it believed it hadn't been successful in setting it up at 2am?
It is possible to tweak the command sequence so that WW only sets the charge enable when it knows the start and stop times have been accepted? Similarly at the end of the slot write the charge enable false command and verify it before setting the start and stop times back to 0am? Plus can it still write the end of schedule commands if the schedule is still enabled even if it timed out on the start of schedule commands? This way I think it would avoid the inverter attempting to charge a full battery all day and using lots of expensive grid power for the house.
