How do i remove permissions from growatt?
i cant get ww to work, my battery has stopped charging since sign up.
    PANface Your smart schedule and export schedule have not been enabled and no automation has run from Wonder Watt. Your activity log is empty.
    9 days later
    10 days later
    I’ve tried to input my api details in the settings section on wonderwatt site for my GivEnergy system, but I’m unable to connect and keep getting a message saying “error accessing data - check api key.” I copied and pasted my api key directly from my octopus energy account so I haven’t mistyped the key. I have a GivEnergy hybrid 3.6 gen2 inverter. What am I missing? TIA
      hazelst3
      Not really my place to say, but you need to put the API key from your givenergy portal and I believe (as this has changed) set Wonderwatt to control your inverter. Not sure about anything else on the list?
