This is coming up this am. Inverter is online and nothing has changed this side:
Date (Europe/London) Battery SOC Solar forecast (kWh)
2024-10-20 04:30:05 N/A %
Error accessing data - check API key [o58pgg5G]
2024-10-20 03:29:52 N/A %
Error accessing data - check API key [tV2Ui5jV]
2024-10-19 15:55:06 N/A % 10.9 kWh
Error accessing data - check API key [bbwgdwWa]
2024-10-19 11:58:57 N/A %
Error accessing data - check API key [kCL2iuV8]
Seems WW has no access to the Inverter at all - there is no status data either. I can access it locally and can control it through the Giv Portal so maybe this is an issue WW side...
