I have a scheduled full export 4-8pm every night.
Sometimes the command fails to the Inverter. If this is the case there appears to be no retry attempts for export and:
- I loose the complete export window.
- There seems to be no easy way of resending this manually - not as if you can just click on a button or time slot like you can with agile. Only way I think is either to manually do it outside of WW or delete the stored schedule and re-input it with a later start time to it has another go (and then have to alter the schedule back again afterwards)
Can the system not be made to retry in x mins as it does with agile?
