For those of you on Agile, I presume you probably already keep an eye on things with the likes of Agile Predictor or Octoaid.
However, if you're not already aware, this is useful for a week ahead forecast...
Embedded wind and solar forecast
The closer the green (wind generation) is to the red (demand), the cheaper Agile is. Typically, above 15000MW is single digits, around 20000MW will likely be zero or negative.
Unfortunately, the next 10 days is looking a bit grim.
Hope this is useful to some of you.
