Can someone reassure me that when a WW timed charging period ends my givenergy battery will revert to eco mode and discharge to satisfy home demand?
Or do I have to do something to make this happen
Thanks
What happens at the end of a set charging period
Well I can answer my own question now because the charging period just ended at 07:00, the battery is full but not discharging to meet home demand so I'm importing from the grid now - not the desired outcome. So my question is using WW can I get my battery to revert to eco mode at the end of a timed charge? I'm sure this is what everyone is doing so please could you advise me what to do now
Thanks everyone
In case needed my id is mellow-ask
Looking through the previous threads I see my question has been asked before but I couldn't see the answer....
mellow-ask again, I checked and indeed eco was toggled off in my GE, I manually toggled it on and now the battery is discharging... Not sure what to do now
I also saw that timed charge 00:00 to 00:00 was toggled on in GE.... Is this something set by WW? And should I leave it as is? My next timed charge is supposed to start at 10:00 to 13:00 hopefully the eco mode will be enabled after that. Any thoughts/instructions much appreciated
Do you have ‘Hold Charge’ set to ‘No’?
Pourl Thanks - I'm not sure - where do I find that setting so I can check it?
Steve-Gibbs A timed charge should not disable Eco, we do not touch the Eco flag for AC Grid charges.
We do reset it for some of the forced discharge/export ones though, as that is required on some of the Giv inverters.
Pourl @Steve-Gibbs is using custom Schedules, not Agile. So On Hold in between Agile slots is not applicable in this case.
Steve-Gibbs Can you provide the Giv logs from that time please? You find it by going to Remote Control and find it at the bottom of all the Inverter registers/settings.
We can check there what was responsible for disabling Eco when the start charge was issued.
