admin I’ve been monitoring actual solar generation against the forecast for several days.
Here’s the results: forecast / actual
8.7/2.1, 4.6/2.1, 3.4/0.3, 10.6/4.7, 3.8/0.3, 4.5/1.7, 6.1/1.4, 3.8/0.1, 3.8/0.1
As you can see there is little correlation. I don’t believe there is anything wrong with my panels or inverter. The panels are clean, both strings are generating. My location, orientation and roof pitch are set up correctly.
I know it is very early days but I am wondering if you have seen similar discrepancies from other users. Perhaps accuracy will look a lot better when we get some actual sunshine!
terrible-guidance
