ALLENPATTRICK I have schedule an export/discharge session between 2000 and 2229 tonight prior to tomorrow’s price dip. This has successfully saved as a one-off though shows with red arrows in both todays and tomorrows slot schedule. If this is still the case after tonight’s run I will delete the unwanted session for tomorrow.
That is just a display issue. And after the one-off schedule gets deactivated should look as you'd expect.
ALLENPATTRICK I appreciate that tomorrow’s prices are released from 1600 and typically this is reflected immediately afterwards and WW recommendations around 30 minutes after this. It is sometimes disconcerting to find that my user settings have been disturbed and need to be reinput. Would I be safe to conclude that WW recommendations once set can confidently be amended (and saved) by users without any subsequent refresh obliterating them? If not could you suggest a suitable ‘safe’ time that our schedules can be set.?
We auto-populate around 16:35 - it's been suggested we lock the schedules between 16:00 and 16:35 for modification, which will prevent most of this from happening.
