We had a change to our power feed planned for this morning so I wanted to pause my schedules just in case of any clashes but inadvertently hit pause before the end of the charge schedule. WW was very tidy, it issued :
2024-01-19 06:13:18 You AC Charge Upper % Limit Written Successfully 100 15 15 API - Inverter Presets
2024-01-19 06:13:17 You AC Charge 1 End Time Written Successfully 07:00 00:01 00:01 API - Inverter Presets
2024-01-19 06:13:17 You AC Charge Enable Written Successfully true false false API - Inverter Presets
2024-01-19 06:13:15 You Enable AC Charge Upper % Limit Written Successfully false true true API - Inverter Presets
Which was good news, however it didn't do a reset the charge power to maximum as it would do at normal session end.
