Hi, I wanted to charge using the timing on my invertor last night so I set it to the 5hr overnight slot. I disabled my scheduled charge in WW. I woke up around 03:15 to find that batteries were not charging and the timed charge on the invertor was reset to 00:00 - 00:00. My question is why did WW override invertor settings when there was nothing scheduled via WW
2025-01-20 20:37:14 You AC Charge 1 End Time Written Successfully 05:29 00:00 00:00 API - Inverter Settings - Wonder Watt - NQ1l0RtT
2025-01-20 20:37:13 You AC Charge 1 Start Time Written Successfully 00:31 00:00 00:00 API - Inverter Settings - Wonder Watt - NQ1l0RtT
2025-01-20 20:37:01 You AC Charge 1 End Time Written Successfully 00:00 05:29 05:29 Portal - Inverter Settings Tab - Timed Charge
2025-01-20 20:37:01 You AC Charge 1 Start Time Written Successfully 00:00 00:31 00:31 Portal - Inverter Settings Tab - Timed Charge
