MickBird Morning Bit of a nervous Wally with Wonderwatt!! I have moved to Cosy. Just checking I’ve set up to most cost effective level. So… I have scheduled x3 charges at the off peak hours. Do I need to set a discharge schedule for the 16:00 to 19:00 peak? Ps . All charges to 100% Thanks for your support and patience Mick Bird
admin MickBird Sounds good. No discharge is needed, as your Growatt system will simply use the default Load first setting outside of charges or forced discharges. You may want to run a forced export with more sunny days. Depends on your export tariff too.
