Plugged EV in and was allocated charging slots in standard overnight cheap rate.
Battery quite full so decided to discharge some power from the battery to the grid. Next thing the EV is charging and draining the battery but this wasn’t showing as a dynamic slot on IOG. This has happened before. Would WW pick this up within a few minutes as not showing on Octopus?
If not other than not plugging in until I’ve discharged, how do I stop this happening?
