elaborate-routine
I've been using the above Agile Charge window settings for a few weeks now to ensure that I have enough charge to get through the lower morning peak. The aim for me is to just have enough charge so that I don't import at higher rates than my export rate when I know solar will be filling the battery the next day. My overnight usage is very predictable.
Its performance at doing this varies depending on when WW picks up the 3 cheapest slots. If all three occur early in the night the long hold period that follows discharges the batteries so that there is insufficient charge to cover the peak. If I increase the charge level I find that the next night WW picks up 3 cheap slots later in the night and I miss out on some Solar export the following day as I can still have almost 30% in the battery at the end of the morning peak. Another problem is that if all three cheapest slots are contiguous the state of charge is only measured once at the start of the first slot which, if slightly higher than the threshold, means that all three charge slots are ignored needing a higher charge threshold level to be set to compensate.
What would be the best approach to coping with this?
(I also have a similar problem on low solar days with the evening peak which uses a different Agile schedule.)
(My batteries store 8kW and my hold discharge rate is about 330W so effectively they hold charge for up to 24 hours or 35% charge will hold for 8 hours)
