@jsheerin
Appreciate it's in your interest to self consume as much solar as possible.
Don't know if @admin has done some work on this recently but, I've tested the smart charging this week, and it appears to be working as I might have expected.
The settings used are here:
https://app.wonderwatt.com/settings
and here:
https://app.wonderwatt.com/intelli-octo
So, for reference, my battery capacity is 19kWh, and I usually have Normal usage set to 20kWh, Target 100%, smart charging off.
I don't normally bother with the predictive smart charging, as it makes more sense for me to always charge to 100% and export as much solar as possible.
Test 1:
Smart charging On
Target charge, 90%
Normal usage, 20kWh
Solar prediction, 32kWh
Result, charge to 90% ✓
Test 2:
Smart charging On
Target charge, 95%
Normal usage, 100kWh
Solar prediction, 31kWh
Result, charge to 100% ✓
Test 3;
Smart charging On
Target charge, 90%
Normal usage, 40kWh
Solar prediction, 10kWh
In all three instances, it charged the batteries exactly as I would have expected.
I'd be interested in any feedback.
