Hello,
I have two 10000TL inverters running in parallel mode. 6kw PV and 33KW LFP battery.
I have been unable to get rid of the Grid-off message on the top line, so my inverters will not use Grid to supplement the system in ZeroExportLimit mode.
When I had one inverter running in my shop in 'test' mode this worked. I had hooked into a sub panel in the shop.
I thought perhaps the bonding wire between Earth and Neutral was the problem, but removing it this morning did not change a thing.
I do not see anything out of the ordinary on the Grid details page. Did the normal stuff of making sure the phases were the same everywhere, and the CTs were installed correctly.
I have kind of run out of ideas, looking for suggestions...
What I have now is a 10kw off-grid inverter (actually two of them).
Thanks in Advance!
GlenB
