PeteC We have other users on dual AIO set ups that are just fine. We pick up the Gateway and send instructions to the Gateway serial instead.
What is your WattID please? So we can check to see what's going on in a bit more detail, thanks.
PeteC It's not working properly
What specifically? What serial is showing when you reconnect from the Settings page?
As far as I'm aware it's the dynamic charge rate that currently cannot be set, as we need to use percentage settings. This was mentioned in another thread.
Apart from that, everything should be working.
