I had a scheduke set up tonight to discharge to the grid between 18.00 and 19.00 only to run if the battery was over 70% and to stop at 55% The activity log shows it should have stopped discharging at 18.51 but it carried on and by the time I noticed it was down to about 30% I managed to stop it by going into inverter settings on the givenergy app and found there was a Timed discharge slot set until midnight. I turned this off and export stopped. The battery is now at 25% My watt id is ''shocking-fortune''
