Ibizan I don't know for certain, as I've not tested it, but I suspect the kill switch you need is to pause the IOG integration only here:
https://app.wonderwatt.com/pause
Then in the Giv app/portal, set the charge start/end times to 00:00
On a side note, I'm curious as to why you wouldn't want to charge to 100% every night and export all xs solar during the day. This is usually the most lucrative.
Possible reasons:
You're on FiT with deemed export, or
You have an potential generation in xs of your export limit, so you're trying to avoid clipping.
In that case, you're potential solution is to switch on smart charging, with a charg limit, here:
https://app.wonderwatt.com/intelli-octo
Then in the Giv portal, use "pause charge" for the morning (dependant on the orientation of your panels), and allow your battery to charge from xs for an hour either side of your peak generation.
