brookfield This morning we were lucky enough to have an Octopus PowerUp from 2 am to 4 am so I set 3 schedules taking account of my Eco7 hours from 00:30 to 07:30 also: (1) From 00:30 to 01:59 to charge to 60% at a calculated rate - this worked (2) From 2 am to 4 am at 100% charge rate - WW reported this was successful but it wasn't. (3) From 4:01 to 7:30 to charge to 80%. For this I got a Comms error (iuyAf2Zm) but no retry and no WhatsApp message. As a result my battery ended up with <20% charge as it has been drained by all the other appliances I set to go off during the PowerUp. Can you explain what happened? https://photos.app.goo.gl/6SsuBXbfAkwAPC2v9 https://photos.app.goo.gl/RDeM546SMquMVGVg6
admin brookfield For this I got a Comms error (iuyAf2Zm) We will add this specific error to the retryable mechanism. What is your WattID pls?
brookfield admin my WattID is dizzy-neck. Thanks for looking at this. Is there any way to see why the 2 am to 4 am charge request was not carried out?
admin brookfield Your 4 o clock charge failed due to the same Error from comms issue. For the two o'clock one, keep the custom schedule end and start time about 5 mins apart, as a general rule of thumb, or there may be some overlap.
