Mat
This is normal for newer GE inverters. There is always some battery discharge even when you set it to zero.
Older inverters like my Gen1 can actually set the discharge to zero.
This might not be a good idea because if the grid went down at night and no PV then the inverter would have no electricity and would turn off. By having some battery discharge available, the inverter has a source of power in case of emergency.
