radanby Good evening all, I am excited to see if Wonder Watt solves the issue of the zappi charger draining our battery storage when Octopus intelligent Go's smart scheduling is outside of the cheap rate. I am hoping I have set everything up correctly on Wonder Watt however i am worried about settings on other platforms conflicting with Wonder Watt. For example the battery storage is currently set to charge overnight through the Shine app for the Growatt battery and inverter. Do I need to remove any settings in the Shine app?
admin radanby We will overwrite the slot in the ShineApp, but if you have more than one schedule set up, they could cause conflicts, yes.
radanby Thank you. Do I set a schedule in both the schedules section and the Intelligent Go section or just the latter on Wonder Watt?
admin radanby If you are on IOG, you just use the IOG section for charge schedules, they will automatically appear, as well as the standard 23:30-5:30 slot. For forced discharges/export, you would use the custom schedules section.
