A comms error overnight meant that WW couldn't set the battery to charge 🙁 but the EV was charging and I had turned off the Agile HOLD feature so the GE battery charged the EV 😮
Luckily, WW did a re-evaluation 30 minutes later and was able to get the battery into charge mode 🙂
In the morning the battery % was a bit low so I fired up WW to manually schedule some daytime slots but that was snookered by the cloudfare issue 🙁 So had to manually work out which slots to use and charge.
Everything back to normal now and I now realise how much I use WW to make Agile life easier.
