Thanks for confirming. Then I have a feature request for you. I'd love the option to check the SOC for each slot in a window against the desired SOC start condition.
This would cover the following scenario:
Charge window 00:00 to 07:00
5 slots required (00:00, 00:30, 04:00, 04:30, 05:00 auto selected)
SOC start condition 100%
Battery at 70%
Starts charging at 00:00
By 00:45 SOC is 100%
Power is drawn from the battery between 02:00 and 03:00 leaving battery with SOC 60%
Currently battery won't start charging again at 04:00 slot as SOC condition isn't checked. It'd be great if it could start again so by the end of the last charge slot I'm back up 100%
Hold charge covers this to some extent but uses the more expensive slots between the 5 selected.
Hope that makes sense?
Cheers
Mat
