johalareewi Have got Agile window 22:30 to 07:00 with HOLD set and 25% discharge. Worked OK last night but tonight the Battery Discharge power has been set to 0W.
johalareewi Now charging 1st slot block at 23:30 for 60 mins but Battery Discharge Power still at 0W. Not an issue while charging but if power cut happens, then EPS has no battery.
admin johalareewi Yeah - there were some areas where discharge rate for hold charge wasn't being passed and ended up being default. Should be fixed now in release 430.
johalareewi admin The rest of the night went perfectly. EV didn't drain the GE battery during hold slot (3am to 3:30am) but there was enough discharge to run the house.
