Can the SOC Less be defaulted to zero or font in red to grab attention? Set one last night without noticing 100% default so no charge as battery below 100. My fault I know but …
    Pourl Hang on, that is why the 'Less than SOC' is defaulted to 100%. The instruction will be sent if the battery SOC is below this value, and skipped otherwise.
    I noticed you have your Agile charge window set from 12:00 - 07:00?
    That is probably the root cause, use 00:00 for midnight, otherwise it's effectively using 12:00 noon to 07:00 in the morning? Unless that is what you are after?
    Did you change this recently?
    Yes, changed to 12 in error!! That is why I had no charge, my mistake completely. Apologies.
