Just joining Wonder Watt… I have two PV installations, an old 3.6 kWp sound facing array (Excellent FIT) and a new 7.7 kWp East/West array on a separate Growatt inverter supplying 13 kWh battery. Shine has difficulty combining the two systems, can WonderWatt do this?
    @admin Thanks for your reply. I’ll probably just control the new inverter and let the old array do its own thing. I think that generation from the old array just contributes to load or export or battery charging.
      8 months later
      Hello. I have 3 inverters. Any guidance on when you will support this.
      Thanks!
        curry756 Explain a bit more about your set up and which inverter you'd like to control for battery charging/discharging?
        curry756
        I think the better statement here would be 'which inverter manages your battery charge' as WW is primarily focused on the battery management. I have 2 growatt solar inverters that WW is unaware of and a solax inverter that manages the battery charge sessions. Its the Solax one that plays ball with WW
