I saved 4 slots this pm, saved them, however they didn't run. Not the first time this has happened to me. Can you advise what I'm doing wrong?
Brilliant platform though!!
WW id: functional-estate
    Huey If you look in your Wonder Watt Activity log (in the menu), it shows the selected slots (one block) was skipped because your battery was fully charged at 13:30, when the charge schedule was about to start.
    Interesting. I had my EV and the battery scheduled to start at 1.30pm in order not to deplete the battery. Clearly I need to start the EV charger in advance so that it has drawn from the battery and there will be demand from the battery. Good to know. Thanks
      Huey Doesn't look like you had the 'hold charge' set to active on the Agile charge window when this charge slot happened?
      Otherwise it would have held the charge, exactly for the purpose of not depleting battery into the EV.
      Thanks for the response. These slots weren't part of an active window. I just chose them at around 11.00am this morning. The only active window is my overnight one and Hold is active during that one.
