admin I have been searching the GiVEnergy forums and have come across this suggestion as to the way the Giv inverter and Battery work by daveharding100 who seems very knowledgeable.
"When forced charging ends because the Charge Period has ended, the system reverts to its default state.
If forced charging ends because Battery Charge has hit a limit, the system enters one of two modes:
Grid = Load Mode, if Battery Charge < Upper SOC % Limit
Battery Idle Mode, if Battery Charge = Upper SOC % Limit work ."
My battery seems to go into idle mode because the Battery Charge = Upper SOC limit % could this be the cause of my issue ? . I am going to try an follow dave's suggestions for settings to see if I have something wrong.
I use the iPhone Giv App but mainly The Giv Web Ui because I understand that the App can be a bit flaky and I cannot see System Modes only Inverter settings. Maybe a stupid question I have looked round including the remote control area and cannot see anything that refers to Solar + grid etc, where is it ? . The only similar option is under the Smart Tariff menu on the App. I have "Stop Automations" selected as I am using WW rather than selecting "solar & battery" under the GIV App > Smart Tariff. Is that correct ?
