Hi
A feature request please. Could we please get a pause charge schedule for agile based on a export price parameter?
The logic behind this is as follows:
If there's charge slots in the day that are cheaper than my export costs (< 15p in my case), then i want my solar to go to export and then charge my battery on <15p electric.
an example:
cheap day (cheap slots in the afternoon):
Pause charging 07:00 to 13:30 (excess solar goes to grid rather than battery @ 15p/KWh)
Charge 13:30 - 15:00 on cheap agile slots (10p/ KWh)
Expensive day (all daytime slots > 15p)
Dont pause charging, and charge from solar as no slots meet the defined price threshold (sayt 14p to account for losses). Export will then only happen after batteries are full
Agile charge slots likely to be skipped or will just top up battery if not fully charged by solar
This will maximise export revenue when its cheaper to buy than to use solar. I'm currently doing this manually through the Giveneergy portal, but it would be great to be able to automate it along side the agile charging. Currently if i dont adjust the pause charge in the GE portal correctly, it blocks the WW charge command. If i fail to remove the pause charge schedule in GE on expensive days, then i end up buying at more than i'm selling.
Cheers
Mat
